Very sick looking coolant !
Old Jul 18, 2013 | 08:30 PM
BCDisco2Lando's Avatar
Default Very sick looking coolant ! UPDATE
Well after an overheating issue we tracked it down to a clogged rad.
While pulling the rad out I decided to dump the rest of the coolant out through the outlet side and just had coolant comeout, then decided to dump the rad out the inlet side and to my surprise this is what came out,
This could really be an issue for coolant flow through the rad so instead of flushing this crap out we decided to go new and replaced the t-stat with a 180* one as well as flushing out the engine.
We are hoping to be back up and running this weekend, fingers crossed.
Oh we also noticed the throttle body heater may have been leaking so may do a bypas, any thoughts on this.
Old Jul 18, 2013 | 08:39 PM
What about replacing the rad? Flushing the skinny D2 rad is usually not worthwhile. You can eval rad by letting vehicle warm up, and check temp top to bottom on fins. If cooler by 10F on lower rows, sludge is on the inside. Note chips in pix, they'll go all the way across.
Old Jul 18, 2013 | 08:45 PM
What abouyt replacing the rad? Flushing the skinny D2 rad is usually not worthwhile. You can eval rad by letting vehicel warm up, and check temp top to bottom on fins. If cooler by 10F on lower rows, sludge is on the inside.
New rad and t-stat already put in, the coolant temps in the old rad ranged from extremely hot at the top to ice cold at the bottom=dead rad.
Old Jul 18, 2013 | 09:27 PM
coors's Avatar
Sounds like you got to the bottom of this one. For future forum readers can you post (if available) before and after engine operating temps?
Old Jul 18, 2013 | 09:47 PM
acg's Avatar
acg
Man, it looks worse than my young's son puke! It is bad indeed
Old Jul 18, 2013 | 10:29 PM
Will do, I am also looking at installing an Autometer full sweep gauge to keep real time track of the water temps.
Old Jul 18, 2013 | 10:31 PM
Reminds me of the high school years, oohhh...
Old Jul 19, 2013 | 12:03 AM
jfall's Avatar
Put in a Nissens from Rock auto. That is what I did.
No regrets.
Old Jul 19, 2013 | 12:07 AM
No regrets.
Already done, we orderd our rad from Rimmer Bros in England and it showed up in Canada 4 days later.
T-stat is from Rovers North
Old Jul 19, 2013 | 05:26 AM
drowssap's Avatar
you just have to love dexcool,
if you sell radiators that is.
