Vibration on acceleration and at highway speeds
Old Jul 15, 2013 | 12:51 AM
hurttech's Avatar
Default Vibration on acceleration and at highway speeds
I have what feels to be a driveline vibration when accelerating, also at highway speeds accelerating or not. All 4 u-joints have been replaced with greasable ones, new flex joint, brand new tires. All engine and transmission mounts "look" ok. Only thing i can think of is mounts or a diff going south. Anyone have any other ideas? Thanks!
Old Jul 15, 2013 | 06:47 AM
coors's Avatar
Bushes may be shot causing the vibes. Check Radius Arm bushes, panhard rod bushes, watts linkage. Also, check for play at the tie rod ends.
Old Jul 15, 2013 | 07:11 AM
drowssap's Avatar
have you tried dropping the drive shafts one by one to see if the viberation goes away
Old Jul 15, 2013 | 09:51 AM
Did happen before you rebuilt the drive shaft, did you replace the centering ball?
Old Jul 15, 2013 | 11:34 AM
Hercu's Avatar
Had that on my D1 after 2'' lift.
Mine was so bad that I lost my whole propshaft on high speed and had to walk back almost 1 km to recover it.
Got rid of the Rotoflex coupler and installed U-Joints.
All vibrations were gone !
Wasn't to expensive also.
Regards
Hercu
Old Jul 15, 2013 | 11:38 PM
hurttech's Avatar
I will check the bushings out, new tie rod ends are going on tomorrow.
I will try this.
It did do it before I rebuilt the two shafts, heard the horror stories of the front shaft. They were non-greasable but looked fine when removed, plenty of grease still left in them. I replaced the centering ***** as well, all Precision parts.
Old Jul 18, 2013 | 08:55 PM
hurttech's Avatar
Possible front/rear differential going out? When I changed the fluid in the year is was a milky brown color.
Old Jul 18, 2013 | 09:19 PM
coors's Avatar
I will try this.
It did do it before I rebuilt the two shafts, heard the horror stories of the front shaft. They were non-grease-able but looked fine when removed, plenty of grease still left in them. I replaced the centering ***** as well, all Precision parts.
If I were you the first thing I would do is begin the process of elimination. As drowssap said drop each shaft and go for a ride. See if the vibes go away. If not, move on... Based on the what I read above (you be the ultimate decision maker) your drive shafts sound like they're okay . Let's move forward and rule them out.
Are you replacing all four (drag link and track rod) ends? When you do - even if you think you have the new rod ends on perfectly, pay the $100; a get a four wheel alignment after the install. Trust me Have the alignment technician provide you w/ the before and after measurement printout. You'll be shocked at the results Process of elimination. Moving on...
As far as the "vibration", are you sure it's not tire or wheel related?
Old Jul 18, 2013 | 09:41 PM
acg's Avatar
acg
Did the vibration surface after you installed the new driveshaft?
If yes, it appears the driveshaft may be the cause of the problem. You may need to get it re-balanced. Typically costs aroubd $60 to $100 to take it to a driveline shop to get it re-balanced.
Old Jul 19, 2013 | 08:15 AM
coors's Avatar
That's not good. Drain a little fluid (front and Rear) to see if it's still milky brown. It should look dark golden honey color. Not like a chocolate/vanilla milkshake. That means water entered the diff housing by a broken or blocked diff vent tub.
rsips
Freelander
Jun 18, 2015 08:06 PM
96discokid
Nov 3, 2012 07:59 AM
Disco2001
May 24, 2012 01:19 PM
Discovery_Scott
Aug 10, 2011 09:40 PM
Benhamtroll
Dec 13, 2004 04:35 PM
