Slight vibration at certain speeds, otherwise hunky dory
Old May 23, 2012 | 05:07 PM
Disco2001's Avatar
Default Slight vibration at certain speeds, otherwise hunky dory
I had a look through posts for vibrations but couldn't find something similar enough to what I am experiencing; at a speed just under 30mph there is a vibration in what seems like the whole vehicle. At maybe 35/37mph it goes away and becomes noticeable again at 65/70mph, but at that speed, somewhat less noticeable. Any ideas what could be causing it? I got the front wheels balanced, but that didn't help.
Thanks in advance!
Old May 23, 2012 | 07:07 PM
cer308's Avatar
Sounds like a front driveshaft to me, in my limited Rover experience. The way I knew it was mine is like you said, at low speed it shook a lot, but around 70 I felt it again just at a higher "frequency" so I knew it was somewhere in the driveline.
Old May 23, 2012 | 07:10 PM
G Reeves's Avatar
front drive shaft x2
Old May 23, 2012 | 10:30 PM
oilspotLR's Avatar
Better do the drive shaft before it breaks free and smacks the transmission right out of the truck!
Old May 24, 2012 | 04:39 AM
See those hairline cracks? Imagine what the fractured end will do with sharp and jagged end, turned at speed by the velocity of the vehicle and front differential. Warning can be less than an instant. Presented as an example - your exact conditions may vary.
Attached Thumbnails Slight vibration at certain speeds, otherwise hunky dory-grease_fitting.jpg
Old May 24, 2012 | 01:19 PM
Disco2001's Avatar
thank you all; it was the front shaft. Now the wallet painful part, but better than the alternative as you all point out.
acg
Jul 19, 2013 03:17 PM
Francopacks
Jul 18, 2013 09:44 PM
yloDiscoII
Jan 28, 2011 10:52 PM
TheRedRockDisco
May 5, 2010 06:27 PM
Disco2Fever
May 5, 2010 01:13 PM
