Vibration around 50mph
If its in the steering wheel it is either the tires out of balance or warped brake rotors.
Start by swapping tires front to back, does the vibration move to your butt now or still in the steering wheel?
Front tires out of balance show in the steering wheel, back tires in your butt.
I had the same issue. It did not go away until I changed out the rotoflex coupler in the rear drive shaft. Don't be fooled by it looking alright. You cant tell its condition until it is removed.
I have had the same issue a couple months ago. It was caused by the dysfunctional electrical parking brake, the parking brake pads was loosed so it left too few space between itself and the brake disk, I replaced the EPB and rear brake pads, disks. Then the issue solved. Maybe different cause as yours but hope it can help. When you get the same issue again next time, please check if the rear brakes work properly. Usually it will become too hot to touch.
