Vibration/Pulling
Old Sep 29, 2017 | 08:35 AM
RedRover2003's Avatar
4wd High
Default Vibration/Pulling
Driving last night and thinking to myself how smooth the Discovery was riding. Go into the bar. Have two. Come out, get in, start it up, back out of my space, shift to drive and had to brake to let someone out of a space and noticed a pulsating type of pulling against the breaking I was doing. As I accelerated, that pulsating was actually a vibrating that I could feel through the seat. The power didn’t seem to be there like it usually is, either.
It has been burning oil lately. Doesn’t seem to idle quite evenly.
Im all ears ladies and gents... this ring a bell to any of you? It’s a 2003 Discovery II.
Old Sep 29, 2017 | 09:57 AM
Sixpack577's Avatar
Sounds electrical
Do you have an ob2 code reader?
If not, any auto parts store should be able to get some codes, even without having the Land Rover software.
They can give you a code number you can reference here, or google.
That's free and easy, and likely the best place to start.
You could have the battery and alternator tested too.
Low voltage can cause all kinds of problems.
If you have a misfire, it can have several causes.
If it's burning oil, you could even have a fouled spark plug.
I'm not saying these are definately your problems either, but start simple on your process of elimination.
Where are you located?
Myself or another member may be close to you, and could check for codes for you.
Old Sep 29, 2017 | 10:04 AM
4wd High
Originally Posted by Sixpack577
Sounds electrical
Low voltage can cause alk kinds of problems.
i live in Clover, SC - about 30 minutes south of Charlotte
Old Sep 29, 2017 | 10:12 AM
Sixpack577's Avatar
Sorry, you're 4 hours southeast of me.
Maybe someone else here is close to you.
I'de try an auto parts store, they may or may not be able to help, but it is worth trying.
Old Sep 29, 2017 | 10:13 AM
BackInA88's Avatar
Maybe one of your brake calipers locked up.
Take it for a short drive and put your hand near each wheel and feel for and excess heat coming off one.
Old Sep 29, 2017 | 05:29 PM
Alex_M's Avatar
Sounds like a misfire to me. Is your check engine light flashing? If it is that's a catalyst damaging misfire. If its just on it could still be a misfire, but from your description id guess catalyst damaging.
Old Sep 29, 2017 | 07:57 PM
wjsj69's Avatar
Your description sounds like a bad valve(s)/valve guide(s) to me. The burning oil is what makes me thinkest so. Have the head gaskets ever been replaced, heads inspected? I would pull and check all the plugs for oil fouling as part of your troubleshooting, along with what the others have suggested.
Old Sep 30, 2017 | 08:49 AM
LR03NJ's Avatar
Likely the caliper/s froze or stuck.
Old Oct 1, 2017 | 03:04 PM
OffroadFrance's Avatar
It could be many things from a stuck/binding caliper, front driveshaft, engine/gearbox mounts or a slight misfire. Try a code reader for some ideas rather than guessing.
Does the noise increase with the speed of the truck?
Old Oct 1, 2017 | 06:57 PM
The Deputy's Avatar
Sounds like a rear caliper is hung up, drive it, jack up rear axle, try and spin wheels, should turn with little resistance.
Brian.
