Vibrations
Old 11-08-2019 | 02:21 PM
landroverdude's Avatar
Default Vibrations
Omg what is up with this thing, I have been having these crazy vibration's when low speed or high although high speed is worse at 70mph my backseat looks like a nasa space shuttle about to take off, recently in the past couple months I have got new springs and shocks, wheel bearings, steering damper and steering rod and drag link, anyone have any idea as to what is up?
Old 11-08-2019 | 02:30 PM
User's Avatar
Driveshafts are common to fail and take out your transmission
stop driving it
specifically u joints
Old 11-08-2019 | 02:32 PM
stop driving it
Well actually I just replaced the front driveshaft with a heavy duty one from great basin rovers, although the back one is still stock I kinda thought that would be a problem,oh boy it is isn't it?
Old 11-08-2019 | 02:34 PM
Sixpack577's Avatar
Could be as simple as a wheel weight got thrown off.
Have you had your tires balanced?
Best4x4 (11-08-2019)
Old 11-08-2019 | 02:43 PM
Not recently maybe like 3 months ago.
Old 11-08-2019 | 03:03 PM
Sixpack577's Avatar
It is very possible that's all it is.
I'm not saying 100%, but definately enough to have them checked.
I have seen Many an unbalanced tire cause bad vibrations, including at low and high speeds on the same vehicle.
And, the bigger and heavier the tire, the more noticeable it is.
I would start there assuming you find nothing loose in the driveline or suspension.
landroverdude (11-08-2019)
Old 11-08-2019 | 03:15 PM
Best4x4's Avatar
Also just a bad tire can cause awful vibrations if the belt inside the tire itself has an issue.
The following 3 users liked this post by Best4x4:
Ben Matheson (11-08-2019), landroverdude (11-08-2019), Sixpack577 (11-08-2019)
Old 11-08-2019 | 03:16 PM
Alrighty thanks I'll definitely look into that and check my tire pressure as well.
Old 11-08-2019 | 03:30 PM
Dave03S's Avatar
Check your Rotoflex too.
Old 11-10-2019 | 01:55 PM
Tomzsix's Avatar
After reading this post, I went to my tire shop and they did a re-balance ( an ounce off on each tire) and then rotated them. As of now, no vibrations on freeway, and when I brake there is no wobbling, either.
Sixpack577 (11-10-2019)
invalidusername
01-01-2014 10:41 AM
DIIZ
08-18-2013 03:47 PM
1998DiscoverySE
02-10-2012 12:00 PM
brigadier_dj
05-10-2011 12:40 AM
Quick Reply: Vibrations
