Vibrations
Old Nov 8, 2019 | 01:21 PM
landroverdude's Avatar
Default Vibrations
Omg what is up with this thing, I have been having these crazy vibration's when low speed or high although high speed is worse at 70mph my backseat looks like a nasa space shuttle about to take off, recently in the past couple months I have got new springs and shocks, wheel bearings, steering damper and steering rod and drag link, anyone have any idea as to what is up?
Old Nov 8, 2019 | 01:30 PM
User's Avatar
Driveshafts are common to fail and take out your transmission
stop driving it
specifically u joints
Old Nov 8, 2019 | 01:32 PM
stop driving it
Well actually I just replaced the front driveshaft with a heavy duty one from great basin rovers, although the back one is still stock I kinda thought that would be a problem,oh boy it is isn't it?
Old Nov 8, 2019 | 01:34 PM
Sixpack577's Avatar
Could be as simple as a wheel weight got thrown off.
Have you had your tires balanced?
Old Nov 8, 2019 | 01:43 PM
Not recently maybe like 3 months ago.
Old Nov 8, 2019 | 02:03 PM
Sixpack577's Avatar
It is very possible that's all it is.
I'm not saying 100%, but definately enough to have them checked.
I have seen Many an unbalanced tire cause bad vibrations, including at low and high speeds on the same vehicle.
And, the bigger and heavier the tire, the more noticeable it is.
I would start there assuming you find nothing loose in the driveline or suspension.
Old Nov 8, 2019 | 02:15 PM
Best4x4's Avatar
Also just a bad tire can cause awful vibrations if the belt inside the tire itself has an issue.
Old Nov 8, 2019 | 02:16 PM
Alrighty thanks I'll definitely look into that and check my tire pressure as well.
Old Nov 8, 2019 | 02:30 PM
Dave03S's Avatar
Check your Rotoflex too.
Old Nov 10, 2019 | 12:55 PM
Tomzsix's Avatar
After reading this post, I went to my tire shop and they did a re-balance ( an ounce off on each tire) and then rotated them. As of now, no vibrations on freeway, and when I brake there is no wobbling, either.
invalidusername
Jan 1, 2014 09:41 AM
DIIZ
Aug 18, 2013 02:47 PM
1998DiscoverySE
Feb 10, 2012 11:00 AM
brigadier_dj
May 9, 2011 11:40 PM
