Volume of Oil
Old Aug 15, 2007 | 02:12 PM
bigugly82's Avatar
Default Volume of Oil
'03 Disco, about 43K miles.
I'm running a KN 3001 filter. About how much oil should I be talking, I'm measuring about 6.25 qts. That sound about right to everyone. I'm changing about every 3K miles. Owned it from 36.5K miles.
-ugly
Old Aug 15, 2007 | 03:11 PM
SpeedAgent's Avatar
Default RE: Volume of Oil
I'm pretty sure the manual says for oil changes it is 6.1quarts, but like 6.5 from a dry engine. I guess dry means rebuilt or new?
Old Aug 15, 2007 | 03:18 PM
jdelp's Avatar
Sounds about right, I'm usually right around 6 quarts but I've used stock sized filters to this point. The 3001 K&N is about twice as big, and I assume displaces a bit more oil.
Old Aug 15, 2007 | 03:31 PM
I use a 3001 filter also and when I fill to the full mark on the dip stick I use about the same amount.
Old Aug 15, 2007 | 04:40 PM
bigugly82's Avatar
it took a little less than 6.5 qts. w/the 3001.
Old Aug 16, 2007 | 12:22 AM
mordor110's Avatar
I guess the ½ qt extra would depend on if you "prime" your oil filter (pour in a bit of oil)or not before installing? I'd strongly recomend filling the filter about ½ full of oil before installing.
Old Aug 16, 2007 | 10:50 AM
bigugly82's Avatar
I did. I didn't want to dump it all over me when installing but I'd say it was about half full when I screwed the filter in. It was actually 5.5 qts on oil and one qt of Lucas.
Old Aug 16, 2007 | 11:53 AM
Darover's Avatar
ORIGINAL: mordor110
It's the first time I ever heard of that!?!? Interesting!
Is this something you do for a purpose??? just for the heck of it??? or its been proven to do something positive???
Old Aug 16, 2007 | 12:09 PM
okdiscoguy's Avatar
keeps your oil pump from running dry.
MINIrover
Jul 20, 2011 10:46 AM
aerokurt
Dec 3, 2006 06:00 PM
mlrny32
Jan 21, 2006 06:44 PM
Petes 03 Rig
Jan 5, 2006 08:13 PM
ssj4_yasir
Audio/Visual Electronics
Oct 12, 2005 08:59 PM
