VSS - Vehicle Speed Sensor Wire in Discovery II
Old Nov 19, 2007 | 02:20 PM
tcbinaflash's Avatar
Default VSS - Vehicle Speed Sensor Wire in Discovery II
I'm looking for the VSS (Vehicle Speed Sensor) wire in my 2003 Discovery. Any idea where it's located? I've been told it's not located in the same position as in the Discovery I.
Thanks,
-Duke
Old Nov 19, 2007 | 05:14 PM
Default RE: VSS - Vehicle Speed Sensor Wire in Discovery II
I believe you will find the D2's don't have a VSS like the D1's did. Why are you looking for it?
Old Nov 19, 2007 | 07:55 PM
okdiscoguy's Avatar
I think there is a vss integrated in the tranny, but the D2 primarily uses the ABS hub sensors for speed.
Old Nov 27, 2018 | 06:32 PM
user440's Avatar
Ok, despite the 150,000 VSS threads I'm somehow not finding what I need. I am hooking up a TerraTrip 202plus rally computer and I need to access the VSS wire to send a signal to the Terra. I tried coming off of the ABS sensor but could not get a signal. Can anyone advise the easiest location to tap into the VSS wire please?
If you care, the PDF for the Terra is here (page 20, 15.4 fig 4):
http://terratrip.com/Manuals/Terratr...%20V1%20EN.pdf
user440
Aug 17, 2019 08:38 PM
TRIARII
Dec 31, 2013 09:33 AM
95_rover
Dec 26, 2012 07:41 PM
Brokenrover
Jan 22, 2010 12:44 PM
mooal5
Jul 19, 2008 11:22 AM
