Wading Depth On A 96 Disco
on
You would need to water proof all your ignition connections as well as sensors. You would nee to relaocate or put the ECU in a water tight container, seal up all the holes in the fire walls and make sure all your door seals are in good shape.
How deep are you thinking you want to go?
Mike
Mike
