Wading Depth On A 96 Disco
Old Dec 20, 2006 | 06:32 PM
allstarbiker592's Avatar
Default Wading Depth On A 96 Disco
What is the wading depth on a stock96 disco. Is there any way to make it so it can cross deeper streams.
Old Dec 20, 2006 | 06:34 PM
Default RE: Wading Depth On A 96 Disco
The top of the tires is safe, any more then that and you will need to do alot of electrical protection and a snorkle.
Mike
Old Dec 20, 2006 | 06:35 PM
How would I protect the electrical stuff. I heard there is something on the frame and if it gets wet the truck will stop.
Old Dec 20, 2006 | 07:09 PM
98roverguy's Avatar
I believe if you have a factory installed cd changer that will need to be relocated. Not familiar with the item your referring to on the frame though.
Old Dec 20, 2006 | 07:24 PM
You would need to water proof all your ignition connections as well as sensors. You would nee to relaocate or put the ECU in a water tight container, seal up all the holes in the fire walls and make sure all your door seals are in good shape.
How deep are you thinking you want to go?
Mike
Old Dec 20, 2006 | 09:07 PM
Where I go hunting there is about a 2 foot deep stream and it cuts the land in half.
Old Dec 20, 2006 | 11:27 PM
2Feet is not a problem, go for it, slowly and at a steady speed, you'll be fine.
Mike
Old Dec 20, 2006 | 11:57 PM
alex of minnesota's Avatar
i think that my owners manual for a 96 disco I with a gasoline engine says that it is safe to wade up to 26", so 2 feet should really be ok.
Old Dec 21, 2006 | 06:45 PM
Ok thanks yall
yoshibond
May 12, 2012 05:19 PM
rbelz
Sep 9, 2008 08:44 PM
lrdisco4
Jan 21, 2006 10:46 AM
brianwi11iams
Oct 7, 2005 03:38 PM
BrianH
Jan 2, 2005 04:43 PM
