'wandering' disco
Old Jan 31, 2008 | 10:56 PM
pilsner's Avatar
Default 'wandering' disco
ok, my 01 disco is doing odd things. ive noticed when i drive on the interstate lately that my girl wants to follow the ruts in the road. this has happened before with other vehicles becuase i didnt pay attention to things like tire wear and air pressure in front tires. i checked the front tire, they have equal air pressure and equal tire wear (to my uncalibrated eye at least). so what do i check next? alignment? i noticed that it is starting to pull to the left under HEAVY braking. brakes maybe? im at a loss.
here is hoping it is something simple...
pilsner
ft lewis WA
01 disco 120k and counting
thanks guys! (and not to be sexist gals too.)
Old Jan 31, 2008 | 11:08 PM
raid13's Avatar
Default RE: 'wandering' disco
check tie rod ends on the drag link and track rod, have a friend
move the steering back and fourth in quick motion with the engine off
as you check movement on the tie rod ends.
also it could be a old steering shock dampener.
hope this helps.
Old Feb 1, 2008 | 08:32 AM
Might also rotate the tires and add another 5 pounds of air to your tires just incase you have a tire with a snake belt starting to show up.
Have you raised the truck, do you have the original suspension?
Roverrocks
Dec 10, 2013 06:05 PM
Roverrocks
Dec 7, 2013 11:31 PM
yloDiscoII
20
Jun 9, 2011 03:43 PM
Elhoff
Jun 25, 2008 12:52 AM
rumpig70
Oct 8, 2007 03:52 AM
