Wanting to keep ride height but soften the ride
Old Jan 10, 2021 | 05:13 PM
  #21
Dave03S's Avatar
Unless you are planning on a lot of articulation then the standard length ones are fine... Otherwise +2", but just by the sounds of it you won't need the extra length.
Old Jan 10, 2021 | 05:28 PM
  #22
Micmac's Avatar
If I went with +2 is there any detriment to a none super articulating set up?
Old Jan 10, 2021 | 07:47 PM
  #23
Micmac's Avatar
looking around at shock availability. TF 178 4 stage +3 looks like something I’d consider. Can you install these on a 2” lifted vehicle?
Old Jan 18, 2021 | 08:22 AM
  #24
04disco2va's Avatar
Originally Posted by Best4x4
You have HD springs meant to handle extra weight. Only way to really keep a decent ride & height would be to install some MD springs and then a 1inch spacer under the coil perches. That will get you a MD ride quality with the same amount of lift. I personally run MD springs on all but 1 of my D2's then I have 1inch aluminum spacers under the spring perches. HD is NEVER going to ride worth a darn unless you have the extra weight on your LR which is what the HD springs were rated for.
Hi Best4x4
just to confirm. If I’m looking to improve my ride from my current setup; TF +2” HD springs TF AT +2” shocks. I should switch out current springs with TF MD springs and 2” spacers. I have ARB front bumper, winch, rear TF bumper and roof rack (rarely used).
Thanks
Old Jan 18, 2021 | 09:50 AM
  #25
Micmac's Avatar
I ordered the TF +3 4 selection shocks for my front. Going to see if a softer shock selection with the OME HD front coils will = a better ride. I will give a report back
Old Jan 18, 2021 | 11:34 PM
  #26
Best4x4's Avatar
Originally Posted by 04disco2va
Hi Best4x4
Thanks
I use 1inch spacers for 3inch of lift total with MD springs.
Old Jan 19, 2021 | 09:54 PM
  #27
disco96sd's Avatar
maybe a My Pillow under your seat
Old Jan 19, 2021 | 10:52 PM
  #28
Best4x4's Avatar
I drive my lifted D2's on the road for 5-6hr at a time and they ride excellent. You have to pick the coil spring rate for the load on your vehicle. It is VERY VERY important, and so is getting the correct PSI in your tires. I always do a chalk test and dial it in perfectly.
I drove up to Austin over the weekend and it felt like I hadn't even driven maybe 30min in a vehicle vs the actual 4.5hr it took me to get there.
Old Jan 20, 2021 | 04:20 PM
  #29
Micmac's Avatar
Installed the TF +3 4 selectable shocks in the front today. Definitely an improvement but not a huge wow factor. I think my next step will be medium springs with a 1” spacer.
Old Jan 22, 2021 | 08:51 PM
  #30
04disco2va's Avatar
Thanks for the reply Best. And thanks Micmac for starting this thread. Looking forward to hear how the medium springs work out.
Micmac
Nov 7, 2019 05:41 PM
Big Jim Swade
Jul 8, 2012 05:03 PM
Baylink
May 4, 2010 12:18 PM
llPANCHOll
Feb 9, 2009 01:49 PM
grrRover
Mar 21, 2008 06:24 PM
