Water Ingress Driver Side
Old Jul 8, 2021 | 01:46 AM
RizzleKicks's Avatar
Guys , if you see where the water is sitting it’s a good bit away from the windscreen and would water travel up stream if the motor is parked on a slight slope facing downwards 🤔
Old Jul 9, 2021 | 11:58 AM
Hey Folks ,
I took a pic of where the water is sitting on the inside but showing from the outside the distance from screen to where water is.
Any advice welcome.
As you can see where my finger is that’s roughly where the water is sitting on the inside.
Old Jul 9, 2021 | 12:56 PM
Richard Gallant's Avatar
Check your roof rack seals that is about where it came in on my passenger side from a roof rack leak
Old Jul 9, 2021 | 01:01 PM
Dave03S's Avatar
Your picture clearly shows a damaged seal on the top corner of the windscreen:
Old Jul 9, 2021 | 01:33 PM
That was an after market seal used as the genuine seal kept pushing out the screen.
The non genuine seal fitted by the windscreen technician was then sealed in both external corners with silicone etc.
Old Jul 9, 2021 | 02:03 PM
dswilly's Avatar
I think roof rack but also check for stress cracks in the rain gutters. Look into the gutter from above. As with most cars these areas were sealed with body sealant at the factory. Over time it gets brittle and cracks with road stress and flex, then leak.
Old Nov 24, 2021 | 05:08 AM
Hey Folks,
Still no luck with this
RizzleKicks
Feb 6, 2023 09:24 PM
RizzleKicks
Jun 27, 2021 10:54 PM
isaad0329
Jul 17, 2019 08:13 AM
Geo
Jul 6, 2019 09:24 PM
woodc85
Mar 28, 2019 08:51 PM
