Water leak from flange behind cat.
Old Jun 22, 2008 | 06:14 PM
meltdowndave's Avatar
Default Water leak from flange behind cat.
I was checking the ATF level in the tranny when I noticed some water droplets coming from the flange just behind the driver's side cat.
It wasn't 20 seconds before I was under the car after turning the ignition, yet the water was piping hot. It has also left a sooty residue on the bottom of the flange. It was a cold start and the AC was off, so I think that I can rule out AC condensation.
I've noticed some black patches on the garage floor but thought it was due to AC condensation dripping down after the truck was turned off. I guess now it's due to the leaky flange.
Anyway, what can I make of this? Is it as simple as tightening the bolts or will something more involved be required?
Side note, if there is a slight exhaust leak at that joint what kind, if any, noise would I expect?
Thanks.
Old Jun 22, 2008 | 06:25 PM
Default RE: Water leak from flange behind cat.
The only thing thaty will leak back there is the a/c drain off and water from an exhaust pipe if it has a leak.
Might want to get under there with a flash light and look closer.
khandrh
Dec 20, 2013 04:09 AM
t_wet20
Oct 31, 2012 11:52 AM
elboy0712
Dec 19, 2010 02:48 PM
dammad
Jun 17, 2007 09:14 PM
walteroscar
Apr 28, 2006 10:10 AM
