Coolant leak 'behind the water pump'
Old Jun 17, 2007 | 07:09 PM
dammad's Avatar
Default Coolant leak 'behind the water pump'
I dropped by Disco'00 at the local shop to get some tires changed and asked them to look at a coolant leak I've been having.
They are claiming it is coming from 'behind the water pump somewhere' and are wanting to take it off to look more.
Any pointers for what the leak could be around there?
Old Jun 17, 2007 | 09:14 PM
EVN137's Avatar
Default RE: Coolant leak 'behind the water pump'
Dammad
Very tight quarters in that area. Either the water pump or hose problem.
Have you been loosing coolant at a good rate ( telltale coolant below the engine where you park ).
If the coolant leak is not grossly apparent, I suggest a pressure testing of the coolant system.
Ed
rzuluaga
Mar 1, 2016 08:38 AM
conmetal
Jan 14, 2013 10:16 AM
klaine1
Jan 6, 2010 08:22 PM
meltdowndave
Jun 22, 2008 06:25 PM
walteroscar
Apr 28, 2006 10:10 AM
