Water leak & kangaroo hopping!! TD5
Old 05-17-2007 | 01:04 PM
stokiemike's Avatar
4th Gear
Default Water leak & kangaroo hopping!! TD5
Hi all,
Have got a very slow water leak but cannot find it on my W reg TD5. Have performed the following checks.
> Coolant system has been pressurised for 2-3 hours - passed
> Gas tested the cylinders - passed
> Ran for 2 hours in the workshop - no leak
> Got no water in the oil
> Got no oil in the water
It looses about 1 pint every 150 miles. Allot more if towing or over weight.
Can hear sloshing behind the dash too.
Recently the disco has been kangaroo hopping at constant revs
Any ideas???
Thanks in advance
Mike
Old 05-17-2007 | 07:21 PM
Adz's Avatar
Adz
Default RE: Water leak & kangaroo hopping!! TD5
Was the pressure test done with the heater on or off? If off then it's likely your heater matrix is leaking into the dash - if the heater was on, then I dunno
pgaukroger
02-29-2016 06:56 AM
G Reeves
11-06-2013 09:38 PM
OffroadFrance
09-30-2013 07:40 AM
trini defender
Defender
12-11-2006 06:14 AM
Brian
10-24-2004 12:59 PM
Quick Reply: Water leak & kangaroo hopping!! TD5
