water-meth injection
Old Apr 28, 2010 | 08:41 PM
tatmcc's Avatar
Default water-meth injection
has any one considered putting a water-meth injection kit on a disco? looking to increase hp and mpg.
Old Apr 28, 2010 | 09:02 PM
hilltoppersx's Avatar
don't waste your money trying to increase HP on a disco. what MPG are you getting now?
Old Apr 28, 2010 | 09:06 PM
greenwade's Avatar
Water-meth works great.... if you are running boost. I think that you would see little if any gain in power or mpg on the rover with it. The money would be better spent on some plugs, wires, and a free flowing exhaust. jm2c
Old Apr 28, 2010 | 09:16 PM
tatmcc's Avatar
im getting 14mpg right now with 265 76 r16 muds and a 2in ole man lift i have a k&n cold air intake.
sometime in next 3-4 years im swappin out the dico gas for a 4 cyl cummins
Old Apr 28, 2010 | 11:02 PM
Camdisco24's Avatar
Do you have room for the lab?
j/k... What are you doing to increase your MPG right now?
Have you done an induction cleaning recently? Have you run a fuel injector cleaner through your gas tank?
Old Apr 28, 2010 | 11:27 PM
instg8r's Avatar
running water meth will actually cause your rover to run richer then it is now.
water meth is a tool for predetenating supression.....
Old Apr 29, 2010 | 12:46 AM
Danny Lee 97 Disco's Avatar
Leave the METH-AMPHETAMINE alone, that stuff is bad for you, no matter how much water you take in.
Old Apr 29, 2010 | 08:16 AM
JavaDiscoII's Avatar
Do you guys ever use the LR fuel system cleaner (LRN5010)? I assume it does the same thing (except being $20)...
Old Apr 29, 2010 | 08:21 AM
what kind of disco do you drive? the oil from a K&N will kill the MAF sensor in a D2.
Old Apr 29, 2010 | 08:34 AM
tatmcc's Avatar
i am driving an 02 disco. i havent had any problems with the maf sensor but the gains i got from the filter are worth it. i have a lot more low end power on the highway there is not a need a to downshift as much.
