Water now misfire need help
2000 disco
motor rebuilt top hat sleeves 4 years ago and maybe 8k on the motor.
put magnecor wires a year ago with new bosch MAF and new plugs.
Ive gone thru many puddles of water and never had an issue. Well we were at the end trail and I ran thru nice puddle and sure enough my service engine light came on. Starting running really rough intermittently. Final I checked the air cleaner and there was some areas of the filter that were slightly damp but nothing of dripping water. I made it home with intermittent mild loss of power going up some hills. Code that came up was misfire cylinder 4 and general misfire.
As of now I’ve replaced:
MAF( Bosch) sensor
CPS sensor
checked spark plug with tool light seemed fine.
replace plugs just in case.
compression cylinder 4 165psi cylinder 6 168psi
leaked down test of cylinder 4 less 10% cylinder 6 11%
I got new coils(Bosch) but I haven’t install them yet. I’m not sure what else it could be. Fuel injector for number 4?. When I put the new MAF it ran about 45 min before the code came up again. Now it comes up after 5 min. When I do the live data stream on my i930 obd it does show some misfires at idle. When I give it gas the misfire counter pauses. Unfortunately my obd doesn’t specify what cylinder. Any advice would help.
thanks
MAF( Bosch) sensor
CPS sensor
thanks
