Water and Oil Gauges / Recommendation any?
Old Oct 3, 2013 | 11:12 AM
san988's Avatar
Default Water and Oil Gauges / Recommendation any?
After reading a lot of the post, I got to the conclusion that a pair of gauges wont hurt. I'm thinking of getting a water temp gauge and a oil pressure gauge. Can someone make a recommendation and some installations suggestion? Thank you!
Old Oct 3, 2013 | 11:22 AM
Many do a pod up the side of the A pillar. Voltmeter also is popular. So is the Ultra Gauge, which is a live data code reader, has other features, won't do oil PSI. UltraGauge OBDII Scan tool & Information Center About $70, plug in.
Somewhere I saw a pix of an oil gauge mounted under the hood, just for diagnostics. Guess if you check it with weekly underhood fluids and belt review it wouldn't hurt. Of course I can't say that you'll have too much warning on a rapidly failing oil pump. Perhaps others will comment.
Old Oct 3, 2013 | 11:33 AM
dusty1's Avatar
x2 imo apillar is the cleanest look
glow shift has good products
Old Oct 3, 2013 | 11:58 AM
White Rover's Avatar
I'm a fan of the ultra-gauge and i have a glowshift tow max oil pressure gauge. It works great just a little distracting at night.
Old Oct 3, 2013 | 12:14 PM
honda50r's Avatar
I'm jut running a Sunpro Oil PSI from advanced auto and an Ultra Gauge. Voltmeter wouldn't hurt, but if I go that route I'll need to find a cleaner set-up for the cab, I have Oil on left of binnacle and ultra on right. That guy building the RRC made a sweet carbon fiber binnacle for right above the radio
Old Oct 3, 2013 | 12:40 PM
san988's Avatar
Guys, thank you for your replies but if it is not too much to ask can you add some picture of your installations. Beside the ultragauge hanging in the windshield, I don't have any idea how to get the other options installed
Old Oct 3, 2013 | 01:16 PM
jdwilks's Avatar
I had the tinted glowshift gauges in my last car and over 6 years of use I never had an issue with them. I still have the oil pressure and vacuum gauges and plan to pick up an inline water temp or maybe something else (I have an ultra gauge) I just need to get the time to mold in a gauge pod so it looks clean
Old Oct 3, 2013 | 02:39 PM
0304Disco's Avatar
I also use Glowshift Oil psi and Coolant temp gauges and have been very happy with them for years. I mounted the gauges on plastic right in front of the CDL shift lever, just above the Sticker for CDL operation.
If you do need to use the CDL you'd need to remove the screw on plastic handle and shift the CDL using the metal lever. I don't use the CDL much so its never a problem.
I used the pods that the gauges came with and double sided tape to adhere them to the dash plastic so I didn't need to drill up anything.
This way you don't have them in your face all the time like on the pillar mount. If something is going withe either system, one of the the gauge alarms will notify me so no need to look at them all the time.
Old Oct 3, 2013 | 02:49 PM
0304Disco's Avatar
Install.
Attached Thumbnails Water and Oil Gauges / Recommendation any?-glowshift-001.jpg
Old Oct 3, 2013 | 03:51 PM
san988's Avatar
Quick question, how did you install the oil PSI? Oil Filter Sandwich Adapters?
Thanks.
