Water Pump
Old Feb 3, 2024 | 10:23 AM
Edm_disco2's Avatar
7th Gear
Hello All,
new 2001 Disco2 SE 4.0 w/ACE owner. Just wanted to confirm if you guy are talking about this water pump?
Old Feb 3, 2024 | 03:03 PM
acg's Avatar
acg
The Airtex brand was pretty popular for a number of years. Airtex used to offer two versions, either a steel or brass impeller. The brass version was apparently was more reliable. But I believe it is no longer available. You can still find Airtex pump with the steel impellers.
This Flowcooler version came out a few years ago and has had good reviews. Some have reported more flow rate which is what our engines needs (ie, narrow overheat cooling range):
https://flowkoolerwaterpumps.com/en-...ery-water-pump
Old Feb 3, 2024 | 03:39 PM
YETIX's Avatar
I installed a Flowkooler in my Disco and it works VERY well. Much lower temps then before although I also did the inline thermostat modification at the same time. Those two together mean I have ZERO cooling problems
Old Feb 9, 2024 | 12:01 AM
Wheelspin's Avatar
Flowkooler worth the money, noticeable drop in temp
Tumbler
May 23, 2021 12:01 AM
primo
Apr 28, 2011 09:09 AM
doddsy
Jun 29, 2009 06:02 PM
RangyEvan.CountyLWB
Mar 19, 2009 04:21 PM
steveyogi
Sep 28, 2007 12:19 PM
