Water Pump
Old 03-06-2018, 07:40 PM
Richard Gallant's Avatar
Received 1,132 Likes on 781 Posts
Default Water Pump
Just looking for some advice are there any brands to avoid or better brands ?
I am about to swap out my Fan clutch and fan, assuming all "appears" fine I will leave the water pump alone for now.
But Murphy does tend to show up when least expected so I would like to prepared if leaks happen.
Old 03-06-2018, 07:59 PM
Alex_M's Avatar
Cheap has worked fine for me. I just called up Lucky 8 and ordered one; didn't ask the brand or anything, just ordered what was cheap. There's no big differences between the brands. They've all got a cast aluminum body, a likely Chinese bearing, and usually a stamped steel impeller. Sometimes a brass impeller, but that's an expensive and needless upgrade.
Richard Gallant (03-06-2018)
Old 03-06-2018, 08:45 PM
Thanks Alex, that works for me
Old 03-06-2018, 11:32 PM
Frank4's Avatar
In my experience and I am few others will chime in here, you get what you pay for every single time. I’ve had a couple WP and the cheap ones start spewing from the weep hole much sooner than the more expensive ones.
The following 2 users liked this post by Frank4:
DavC (03-07-2018), shanechevelle (03-07-2018)
Old 03-06-2018, 11:47 PM
There is that but, I have seen everything from around 100.00 Canadian to well over 300.00 And I don't buy there is that much difference, in quality. However one cheap one I saw had a very rough water channel so your point is taken.
Old 03-07-2018, 10:02 AM
shady milkman's Avatar
I went with the airtex with the brass impeller. Pretty sure it had a lifetime warranty
Old 03-07-2018, 12:40 PM
acg's Avatar
acg
acg is offline
Hey Richard,
I installed the Airtex one with the brass impeller 3 years ago. It has been holding up well.
P/S. Hope you see you at our Founders Day event on April 14th.
Old 03-07-2018, 01:22 PM
Originally Posted by acg
Hey Richard,
You will - should have my sliders on by then with luck
Old 03-07-2018, 02:39 PM
OverRover's Avatar
" Just looking for some advice are there any brands to avoid or better brands ?"
I run Airtex water pumps for one reason..... IMO, that pump as proven itself to work and last the longest.
Just AVOID at all costs a GMB water pump!!!!! Total garbage! If someone gives you one toss it in the trash.
REMEMBER> The cheapest (anything) is NEVER the least expensive in the long run.
Richard Gallant (03-07-2018)
Old 03-07-2018, 02:52 PM
Well Airtex are around 100 CDN so that seems reasonable to me.
Quick Reply: Water Pump
