Water Pump Advice? (failure)
Old Mar 15, 2013 | 08:04 PM
j.dstasio's Avatar
Thanks guys for all the advice.
I got a few parts on order & I'm hoping for nice weather next week. Here is what's coming:
Fan Clutch & new fan (old one was damaged a bit in it's last tangle with the belt)
New water pump
New plug wires (I did the plugs recently, but the wires probably need done too)
(2) front o2 sensors - I got lucky and picked these up on eBay. (2) new sealed AB sensors for $18.50 shipped! Happen to be in the right place at the right time to bid.
Since I paid about $100 less for the o2 sensors than I'd planned, I treated myself to an Ultragauge. I've been wanting one of those for a while *Disco nerd chick*
Old Mar 16, 2013 | 03:09 AM
jfall's Avatar
Yep. Go with Mike's large Impeller Airtex.
Will help cooling at idle.
I put a Hayden heavy duty fan clutch on my - old rotting water pump which has
100,000 miles on it.
no bad vibs (pun intended) yet.
Old Mar 22, 2013 | 08:42 AM
j.dstasio's Avatar
X2 on the clutch. If you held onto the same dance partner, and spun around the dance floor 60 million times (50,000 miles at 30 miles an hour) - you'ld know where every wart was on that partner. Change one part, and what was a minor annoyance to the old one becomes a major imbalance to the new one. When it starts to wobble it is eating metal inside. Fan clutch and water pumps love to jump off the cliff holding hands....
New clutch is like $60 (Chevy 2000 Express van, 4.3 liter, w/o AC). Used clutch from boneyard is like $15 (similary year Chevy / GMC - six inch reverse rotation same WP thread)
Thank you for the analogy. It makes perfect sense to me now. I replaced the water pump & also replaced the fan & clutch this time around. My truck hasn't run this smooth in at least two years. I have had a small shudder at idle & in general it just "felt" rough. No more. THANK YOU!
Old Mar 24, 2013 | 08:11 PM
dparham's Avatar
Im going to look into this too... Since ive owned disco and replaced all the pulleys and cant isolate one pully but I hear multiple whining on startup and just in general... Its light but I can hear it... I isolated it with a tube and stethiscope for engines and just cant pinpoint anything...
Also.. is it possible I put the wrong belt on that could cause this? it seemed to go on ok... was pretty tight but fit... I got it here at a Bennet Auto Supply and it is a gatorback.... it seemed to be more whiny after I put it on or just didnt make a difference but was time to be changed...and when I replaced the pulleys the originals seemed ok but I upgraded to the non plastic ones about 1 year ago just for maintenance...
Wayne
Oct 2, 2020 12:10 PM
Minty Barbo
Dec 14, 2013 10:27 AM
ICECREAMEATER
Jan 30, 2013 05:25 PM
0304Disco
Jun 15, 2012 02:00 PM
seamuspg
Mar 6, 2011 02:29 PM
