water pump change
Old Sep 14, 2010 | 11:24 AM
timdunbar's Avatar
Default water pump change
I have the water pump, fan clutch, and thermostat all on the way and I will be changing them out this weekend. Are there any pitfalls I need to be concerned with? I also do not have the fan clutch removal tool. Do I need one? Is the job more difficult without this tool or is it impossible. I hate buying unitasking tools.
Old Sep 14, 2010 | 11:35 AM
Bundu's Avatar
Banned
You can use any 36mm open wrench, be it a shifter or a normal flat spanner. Use a bar or something to hold the pulley so that you can turn the nut.
Old Sep 14, 2010 | 02:11 PM
lipadj46's Avatar
A proper fan tool will make the difference between a really easy job and a frustrating as hell job because you can't get the damn fan off. Sure you may be able to redneck engineer something and get it to work 50% of the time maybe, but my experience is that it can be very frustrating. I would spend the $40 and get the proper tool, you will use it again I promise.
Old Sep 14, 2010 | 02:39 PM
timdunbar's Avatar
I saw a link in D1 forums for the tool at Advanced Auto parts. Will it work for my truck? As far as I know the D1 and D2 have the same fan clutch. It's only 25 bucks. I just thought of something I went with the imperial heavy duty fan clutch from Advanced, will this same tool fit the new fan clutch.
Old Sep 14, 2010 | 02:53 PM
Bundu's Avatar
Banned
D1 and D2 have the same size nut, so you should be good there. I used the fan clutch tool from Advance, but you could just as well get by with a big shifter IMO. I don't know about the Imperial fan clutch size, that one you will have to figure out for yourself.
Old Sep 14, 2010 | 03:06 PM
lipadj46's Avatar
This is the best universal tool along with a 36mm thin fan wrench or 36mm combo wrench ground thin. Don't bother with a kit unless it has a universal pulley holder. I can get the fan off in 10 seconds with this.
Old Sep 14, 2010 | 08:19 PM
Foe's Avatar
Foe
Where did you get that tool and how much?
Old Sep 14, 2010 | 08:56 PM
lipadj46's Avatar
I got it from AB for $50 but you can get it cheaper on ebay or amazon. Just search for universal fan clutch wrench. I bought from AB because I know theirs is made in the USA and I get things next day from them via UPS ground.
http://cgi.ebay.com/ebaymotors/Schle...motiveQ5fTools
http://cgi.ebay.com/ebaymotors/Unive...motiveQ5fTools
http://www.google.com/products/catal...d=0CCwQ8wIwAg#
http://www.google.com/products/catal...d=0CC8Q8wIwAw#
Old Sep 14, 2010 | 09:16 PM
dcarr1971's Avatar
Save yourself a lot of grief and just buy yourself a 36mm fan clutch wrench. My experience has been that the tools at Advanced and Autozone are worn out. i.e.- the 36mm fan clutch wrench is stretched out to 38-39 mm.
I've had this happen more than once. The $25 for the tool is well worth avoiding the frustration and saving time.
Old Sep 14, 2010 | 10:18 PM
Bundu's Avatar
Banned
You don't need to pay $50 for that tool from AB, the kit from Advanced comes with 2 pieces, one is the 36mm wrench and the other you use to stop the pulley from spinning. It is simple to use and does the job.
