Water Pump Gasket weeping...
Old Nov 10, 2007 | 04:23 PM
Fonzie's Avatar
Default Water Pump Gasket weeping...
I pulled off the front underbelly panel today to install an onboard compressor on to the chassis rail (it's for the AirLift suspension kit), anyway, looking upIsaw a very slight leak from the water pump gasket...barely forming drips, but there is a little bit of corrosion so it must have been like this for a while. There is no noticeable drop in coolant level, so I'm just wondering if I should be very concerned and get this fixed immediately or just keep an eye on it and wait till my next major service?
Old Nov 10, 2007 | 04:58 PM
jwfuller's Avatar
Default RE: Water Pump Gasket weeping...
That's suprising for your early mileage. I would say wait until your 45k service, and then change it out when you are doing your fluid flushes. However, I believe I have seen on here where leaky water pumps are indicators that the bearings and impellers are going bad, if you want to search for it.
Old Nov 10, 2007 | 06:18 PM
You want to keep an eye on it, leaking seals always get worse with time.
Old Nov 10, 2007 | 09:29 PM
Fonzie's Avatar
Thanks guys, I'll keep an eye on it then. I have the LR Assured warranty and I'm pretty sure gaskets and seals are covered, so i'll have them do it at the 45k.
Here's what it looks like:
[IMG]local://upfiles/8144/2376F5C716AD46F4AC66E2B72F04D535.jpg[/IMG]
outdoor7or24
Dec 22, 2014 09:31 PM
ebg18t
Jan 14, 2012 01:55 PM
ljdiscovery
Feb 27, 2010 06:57 PM
Skibum232
Nov 21, 2007 08:39 PM
