Water pump on its way out, or something else?
Old Dec 29, 2023 | 11:44 PM
  #21
Harvlr's Avatar
The compressions do seem to point to an issue. On my D2 I replaced HG’s for coolant in the oil, when the real problem was a bad timing cover gasket. (Just added this for thought).
Old Dec 30, 2023 | 05:19 AM
  #22
Extinct's Avatar
Bought a truck once - owner blew a hose off and overheated it bad. Water in the oil, truck was cheap so I took a chance. Problem was that he blew the front cover gasket due to the overpressure from boiling coolant. Replaced front cover and it ran and drive fine.
Old Dec 30, 2023 | 08:37 AM
  #23
mendenhall2's Avatar
I was easily able to keep my hand on the metal thermostat housing, so I guess that would indicate the reading was correct. I'll do the compression tests on the right bank, as well, and see if any of my local shops have a coolant pressure tester.
Old Dec 30, 2023 | 02:23 PM
  #24
Richard Gallant's Avatar
@mendenhall2 Auto tool rental places usually have them. When my head gasket went I went from 188 normal running to 196 with a factory grey soft spring thermostat. I had a hairline crack.
Old Dec 31, 2023 | 01:43 PM
  #25
I was able to complete the compression test of the other bank. The right cylinders were at 135, 125, 135, and 150. So decent. When I take the compression tester back to O'Reilly's, I'll see if they have the coolant pressure tester.
*Edit* I got a coolant pressure tester from Advance, but it's not doing me much good with the cracks in my expansion tank... We're on hold for now.
Old Jan 20, 2024 | 06:12 PM
  #26
Picking this back up, I was able to complete the coolant pressure test after replacing a few components that were letting pressure escape. I pumped the system up to 20psi, and it slowly leaked down to 15psi over about half an hour. Then, it held at 15psi for three hours before I shut every down for the night. What does this tell us? I believe I read in the RAVE that the coolant system is rated for 20psi. Would it have leaked down to zero if the head gasket was actually bad?
Old Jan 20, 2024 | 08:47 PM
  #27
Discorama's Avatar
The pressure relief valve is set to 1.4 bar (stamped on the reservoir cap). 1.4 bar = 20.3 psi. Everything should be tight at that pressure. Maybe the hoses are expanding slowly and the compressed air cools down that causing the pressure drop?
Old Jan 20, 2024 | 11:43 PM
  #28
Extinct's Avatar
Test again the morning and let it hold all day. It should hold pressure all day, if it does not you have a leak. Likely HG given the 115ps on one cyl, which one was it? if it is an end cyl that is most likely the problem.
Old Jan 21, 2024 | 07:12 AM
  #29
The low cylinder was #5, so not an end one. I pumped the system up to 20psi this morning, and got a very different result. It's cold here - for Florida - at 35F, and I immediately heard hissing from two spots. The pressure was dropping fast. The hose at the cold side of the radiator was bubbling something fierce, so I tightened that clamp and stopped it. But there was also a decent amount of coolant leaking from under hard hose just before the thermostat housing. The RAVE's coolant path diagram is a little confusing to me. Does that come straight from the water pump? Is my water pump gasket leaking? I still haven't drained the coolant and inspected the impeller, since we seemed to be moving away from the water pump being bad.
*Edit* The gasket may have just needed to get wet. I went back out a couple of hours later, and it's holding at 15psi again. I pumped it back up to 20 and there's no hissing. So I'll check again tonight and see if it holds.
Old Jan 22, 2024 | 06:03 AM
  #30
Extinct's Avatar
Metal pipe is coming out of the intake manifold. Seal the leaks and test, if it will hold for 6-8 hrs without dropping pressure you do not have a leaking HG. Suggest you run cap one full turn loose going forward. Explanation here: https://landroverforums.com/forum/di...46/#post887409
