water pump leaking at weep hole
Old Dec 14, 2010 | 08:18 PM
geoffhorseman's Avatar
Default leaking water pump
I have the same problem , what is happening- it is not the water pump itself and that is why you are still having problems. The front section has 2 paws which mesh into the back 2 paws ( i think that this is the part you have been replacing)which are part of the housing. There is a seal with these back 2 paws inside the casing and when I have the front of the pump out I can see the back seal leaking and the flow escaping through the weep holes. I am now going to pull off the casing to get to the back seal
Geoff
LADEROUTE
May 16, 2014 12:17 AM
Dogfan
Apr 29, 2013 09:41 PM
audiS4S6
May 6, 2010 12:14 PM
lipadj46
Jul 9, 2009 04:03 PM
panther9
Aug 7, 2008 08:41 AM
