Water pump and timing chain replacement?
Old Apr 11, 2015 | 07:23 PM
lrjon's Avatar
Default Water pump and timing chain replacement?
I have my front cover off to replace the oil pump. While I am in there, should I replace the water pump and/or the timing chain.
See the attached pictures for the condition of these parts. To my untrained eye, they both look good to me.
The vehicle is a 2004 with 75k miles.
Attached Thumbnails Water pump and timing chain replacement?-dscn8374s.jpg   Water pump and timing chain replacement?-dscn8375s.jpg   Water pump and timing chain replacement?-dscn8379s.jpg   Water pump and timing chain replacement?-dscn8380s.jpg
Old Apr 11, 2015 | 07:34 PM
dusty1's Avatar
Personally I would. Especially if you don't know the miles on the pump and if you have some slack going on with that chain. If no slack and I knew how much pump life was used up, maybe let it slide
Old Apr 11, 2015 | 09:35 PM
thesoundguru's Avatar
Go ahead and replace them. AB has a kit with all the gaskets and the chain if you haven't already got the replacement gaskets ordered.
Old Apr 12, 2015 | 08:39 AM
coors's Avatar
I would replace:
* Gears and chain.
* Water pump (w/ brass impellar) and gasket
* Front seal
You've gone this far, you'll kick yourself if the water pump fails or develops a leak later down the road.
Old Apr 12, 2015 | 11:02 AM
drowssap's Avatar
Replace them
Old Apr 12, 2015 | 12:04 PM
lrjon's Avatar
I assume I should replace the 2 chain wheels along with the timing chain as well?
Old Apr 12, 2015 | 12:30 PM
dusty1's Avatar
Yes, you can purchase as a set
A5scott
Jul 11, 2015 07:25 PM
CaptainCulp
Dec 13, 2014 07:23 AM
Martin Rodriguez
Feb 25, 2014 08:55 PM
DeepBlueWater
Sep 20, 2011 09:21 AM
neroverguy
Aug 19, 2010 12:58 PM
