Water pump weep hole
Old 06-09-2020, 12:09 PM
redwhitekat's Avatar
Default Water pump weep hole
Bought this new water pump 2 years ago from Napa auto parts just last week started to see a bit of coolant right below the water pump on a electrical plug. It’s very little just traces of green stuff doesn’t actually hit the ground
looks like it’s coming from weeping hole
now looking on utube and lurking around some say this is normal and not to worry.
Any thoughts ?
Old 06-09-2020, 06:37 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Usually if it's seeping from the weep hole the bearing is wearing out and the seal is starting to leak.
The Deputy (06-10-2020)
Old 06-09-2020, 08:41 PM
Extinct's Avatar
Received 1,509 Likes on 1,069 Posts
Exactly what Best said. Time for a new pump.
Old 06-09-2020, 09:17 PM
Dammmm gonna call Napa and see what the warranty is.
Old 06-10-2020, 08:45 AM
boston4's Avatar
From what I've heard, the weep hole is designed to be a warning sign of a failing bearing once it starts seeping. Pull or at least loosen the serp belt and check for play in the water pump shaft to see how bad it is. My old water pump shaft was noticeably shot but was not weeping (at least as far as I could tell).
Probably worth just doing the fan and fan clutch while you're there since those are relatively inexpensive.
Old 06-10-2020, 11:17 AM
thanks. Can’t find receipt
called Napa and some are lifetime warranty some are 1 year warranty.
Ill check for play in the shaft
Old 06-10-2020, 01:59 PM
boston4's Avatar
It sounds like people had previously recommended a water pump from some Spanish company that had a brass impeller - this was probably 5-10 years ago. Turns out that since then, the company outsourced their manufacturing to China, and pretty much all of the pumps look the same with a stamped impeller. I just grabbed one from Lucky8 for like $40 US. How many miles did you have on the Napa pump?
Here's a shot of my old and new water pumps:
https://landroverforums.com/forum/di...47/#post728821
Old 06-10-2020, 02:12 PM
[QUOTE=boston4;732632]It sounds like people had previously recommended a water pump from some Spanish company that had a brass impeller - this was probably 5-10 years ago. Turns out that since then, the company outsourced their manufacturing to China, and pretty much all of the pumps look the same with a stamped impeller. I just grabbed one from Lucky8 for like $40 US. How many miles did you have on the Napa pump?
it has maybe 6 k miles and it wasn’t cheap
over $200 cdn
Old 06-10-2020, 02:15 PM
That was back in mid 2018.
I have since discovered rock auto
name brand parts cheap and shipping
Old 06-10-2020, 02:16 PM
boston4's Avatar
Yep - my fridge has a ton of those RockAuto magnets on it.
Quick Reply: Water pump weep hole
