Old May 2, 2020 | 04:19 PM
  #7461
HuskerRover's Avatar
I finally finished my double din dash mod. Started last fall and finally had time to finish with reduced hours.
the only problem I have with it is that I am only picking up 3 stations. I ordered the wye adapter hoping it will solve the issue as I'm only able to use the larger antenna lead right now.
I have scoured the forum and get conflicting ideas on it. From what I've gleaned, the antenna amps get powered with the amp. The amp warms up to the touch, and I have sound by using the metra plug with the pre outs, so, my estimation is that the ant amp is working but needs the second ant.
sorry for the crap pic.
Old May 3, 2020 | 07:26 AM
  #7462
777AIA's Avatar
Originally Posted by Boostle
My truck right before quarantine vs today - let's say I've been busy
want to sell that original front guard?
Old May 3, 2020 | 07:20 PM
  #7463
Discorama's Avatar
Originally Posted by escott16
Finally installed my arb bumper and harbor freight badlands 12000k (ik it’s crap but it was 100$ off and i would use it maybe once a year)
Looks great. One question. Is it possible to install this Badland winch when the ARB bumper is in place already? Or do I have to mount the winch to the bumper first and then install the bumper? The reason I am asking: I need a new bumper and add the winch later because of weight (no lift yet).
Old May 4, 2020 | 05:28 AM
  #7464
escott16's Avatar
I can’t say for sure if it’s possible but once you get all the holes drilled and it’s mounted I’d imagine it wouldn’t be too hard to take off and put back on. The winch was decently heavy being a steel cable one I’m not sure if I would be able to do that easily with it on
Old May 5, 2020 | 08:08 PM
  #7465
The_OGCJR's Avatar
Raptor liner over head front console
  #7466
The_OGCJR's Avatar
Umm sorry for the rotation
Old May 5, 2020 | 08:23 PM
  #7467
MrValingo's Avatar
Went wheeling with a bunch of jeeps. Land Rover's really aren't built to be rock crawlers but I'll be dammed if this thing didn't do what I asked of it. And still make the 4hr trip back home
Old May 5, 2020 | 09:38 PM
  #7468
whowa004's Avatar
If you can get a front wheel on something they generally will go where you point them. They will drag the rear quite often but a little bit of armor and finesse and it never hurts anything. Plus that 4 hr drive home is infinitely better than in any Jeep!
Old May 6, 2020 | 03:04 PM
  #7469
DCDisco2's Avatar
Finally got a ScanGauge and dremeled out a little mount for it.
Old May 7, 2020 | 08:42 PM
  #7470
boston4's Avatar
Good news! Last week, I set out to replace my fan clutch and fan with the Hayden Severe Duty clutch and the Dorman 620 fan that's been recommended by the forum. Once i had it all apart, it turned out that my water pump shaft had a good amount of play. Lucky8 came through with quick shipping and today I installed the new water pump.
The overwhelming majority of my time was spent trying to scrape off the old gasket. Hopefully a "good enough" attitude works here - I genuinely did get nearly all of it off, but there were 3 or 4 little patches of super thin gasket that just wouldn't come off - and continuing to try was chewing up the front cover. We'll see, I guess.
Initial thoughts on the new fan: it's SO loud. Holy ****. Still bleeding the system but so far my temps seem to be the same - maybe a tiny bit lower at idle. I'm sure this will help once I get my AC fixed.
Old pump didn't look too bad, either:
