Water Shedder
Old May 19, 2008 | 09:51 PM
KeizerRover's Avatar
Default Water Shedder
So it would appear that after a loud clunk, and no more window movement, the window regulator on the passenger side front door has died. In the process of attempting, without success, to get the window the last quarter of an inch up to get it completely closed, I encountered the "Carefully release water shedder from door" step. I am assuming that by water shedder they are referring to the thick plastic sheet that covers the interior of the door.
If that is indeed the case, how does one carefully remove it? Mine is edge glued with something that NASA would love to get ahold of for shuttle tiles. Further, the female slots for the clips hold the thing on, as do the bumpouts for the door trim handle screws. So, what am I missing?
Also, is there any way to get the window up that last quarter of an inch or so? The motor is completely buggered so it won't move. Further, it is up too high to access the bolts which secure the glass to the regulator.
Thanks,
Old May 19, 2008 | 10:08 PM
roverguy7's Avatar
Default RE: Water Shedder
rip it. buy a new one when you get your regulator, 10 bucks. or just cut it and tape it back together, they dont come off without tearing unless you plan on taking a few hours to get it off
discoboy
Dec 20, 2012 02:24 AM
ja18
May 9, 2010 07:49 PM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
