Water sound in dash getting worse...
Old May 17, 2009 | 09:42 PM
JBEGIN's Avatar
Default Water sound in dash getting worse...
I know that this topic has been beat to death already, but as the title says, its getting worse... the sound before was just a gentle trickle now its this bubbly babbly brook sound...
the bleeeder screw is missing in my top hose, am i getting air in thru there, is the bleeder screw absolutely necessary? and should i replace any hoses? theyre kinda swollen looking.
Old May 17, 2009 | 09:46 PM
Well if the system were full of coolant then you would not be sucking air.
Replace that bleeder screw and then look for your leak.
Make sure that you top up your coolant.
Old May 17, 2009 | 09:49 PM
JBEGIN's Avatar
will top up system... its like the bleeder screw is broke off inside the hose....
spike you know where i might find that little screw out there? AB? roverparts?
Old May 18, 2009 | 01:15 AM
hollis's Avatar
I have this also.. where do i check the bleeder screw?
Old May 18, 2009 | 07:00 AM
There was a recall or TSB on this part and it was replaced with a new piece.
You still have that "T" piece that that is where the bleeder screw broke isint it?
You will need to replace that whole "T", Atlanticbritish will have it, you might also want to check with your dealer or AutoZone.
Old May 18, 2009 | 10:33 AM
I would suggest you quit driving the truck till you replace the upper hose assembly with the newer up dated hose assembly.
You will toast that engine if you keep driving it cause with no pressure it will over heat about 20 degrees quicker then when sealed.
Old May 19, 2009 | 10:56 AM
JBEGIN's Avatar
ohhhh, just what i didnt want to hear... gonna give local land rover dealer a call and see if they would honor the recall...
Old May 19, 2009 | 11:00 AM
It was not a recall but a TSB as an advisory.
Bite the bullet, go to Atalantic British, like the rest of us have and buy the proper parts.
Old May 19, 2009 | 11:02 AM
JBEGIN's Avatar
Yes sir
Old May 19, 2009 | 11:23 AM
okdiscoguy's Avatar
I would at least call the dealer and price it there before just ordering. Many times, it has been less expensive to get mine at the dealer when you figure overnight shipping, and you can have it that day.
