Water sound in dash getting worse...
Old May 21, 2009 | 10:30 AM
JBEGIN's Avatar
$80.00 @ Land Rover
$60.00 @ Atlantic British
$60.00 @ autopartswarehouse
Atlantic British is close to where I live, i can go up there and save on the shipping by picking it up.
Now when i go to install this new hose... anything i should know before i do it?
Old May 21, 2009 | 01:27 PM
JBEGIN's Avatar
so I think I solved the problem! took fill cap off of expansion tank, started truck, got it up to temperature, and turned on the heater. started squeezing hoses with heater running, and kept topping off as needed. took it for a drive and didnt hear the watery noise, hopefully it solved the problem.
Old May 27, 2009 | 06:38 PM
JBEGIN's Avatar
Im updating my thread... I have the new hose assembly!
Can anyone walk me through changing out thermostat and that hose....
How do the clamps on the hoses work?
Old May 27, 2009 | 06:58 PM
Those factory hose clamps are a PIA, just cut them off and replace them with standard worm clamps.
Old May 27, 2009 | 07:06 PM
JBEGIN's Avatar
was thinkin i should do that, spike... i was just wondering since they came on/with the new hose... pair of pliers squeeze 2gether opens clamp, right? just asking case i cant get the clamps off the new hose, w/0 damaging it lol
Old May 27, 2009 | 10:07 PM
JBEGIN's Avatar
Im just gonna use those clamps, that came with the new hose. asked around, and am told they're better than worm clamps. will be doing this replacement tomorrow
Old May 28, 2009 | 11:42 AM
JBEGIN's Avatar
working on changing out the thermostat and upper hose, got tthem put in. added a lot of fresh coolant(dexcool) and now im ready to try to bleed the air out... need to know how exactly to do this... it would be grate if I could get this one solved, today, thanks!
Old May 28, 2009 | 04:48 PM
Remove the bleed screw and fill the overflow bottle until coolant comes out of the bleed hole, replace the screw.
Turn the heater on full hot, remove the coolant resevoir cap, idle the truck adding coolant as needed to the overflow bottle.
Keep a eye on the temp gauge and make sure that you have plenty of heat coming out of the vents.
Replace the resevoir cap with the engine running.
For the next 2 days after it has sat all night check the coolant level and top off as needed.
Old May 28, 2009 | 09:26 PM
JBEGIN's Avatar
how many times might it take doing this, to fill the system?
did this once only thing different i did was didnt have the cap OFF when idling...
wrong step? just filled it up w/ screw out, replaced screw & reservoir cap and ran the heat on its highest setting. damn , tomorrow im gonna try that with reservoir cap off while runnin... sorry to be PIA with this
OH... truck smokes out tailpipe after starting i noticed, havent niffed it, but disco mike
thinks i may have a head gasket (eeeeep!!) going
khandrh
Dec 20, 2013 04:09 AM
Razorback Disco
Jul 20, 2012 03:35 PM
EstorilM
Feb 22, 2010 12:20 PM
kfox77
Jul 13, 2009 03:31 PM
Jawbox
Oct 10, 2007 09:14 AM
