Water under the carpet
Old Feb 26, 2009 | 02:20 AM
JeremyH's Avatar
5th Gear
Default Water under the carpet
Hi I have just installing some car audio into my 1996 Discovery and found that water has soaked all the underside of the carpet (drivers side UK spec). I realise I will need to take the carpet and underlay/sound deadening out and let this dry. However where are the usual places to start looking, to either seal up, or open ie blocked drainage holes. Any help greatfully appreciated.
Thanks Jeremy
Old Feb 26, 2009 | 08:52 AM
okdiscoguy's Avatar
A\C drains are under the truck above the transmission. 2 little nipples sticking out. If they are clogged, you will get dirty.
If they are free, start checking for cracks in the firewall...
Old Feb 26, 2009 | 09:48 AM
And or, is it coolant or water?
Windshield leaks, sun roof leaks and "A" pillar leaks can also cause this.
Old Feb 26, 2009 | 01:05 PM
LR03NJ's Avatar
Check the door seal. You probably tried to run the wires through. Or check the drain hose between the glove compartment and the console. Or the hole that you made to connect your inverter.
Old Feb 27, 2009 | 02:22 AM
JeremyH's Avatar
5th Gear
Thanks for the replies. Firstly the car does not have a/c fitted, just an old fashioned heater and window! Secondly I have not checked if it is water or coolant, oh I look forward to having a taste. Thirdly I have not checked all the window/sunroof/pillar seals so will do this, and lastly I did not make any holes in the bodywork or cut/move/remove any water seals when installing cable into my car. So I gues it is just a case of checking what water it is and then tracing where it comes from. Thanks guys for your help so far.
legendbridges
Dec 26, 2011 07:33 PM
RenoHuskerDu
Oct 28, 2011 03:08 PM
Aj6543
Jun 1, 2009 11:50 AM
ucfmethod
Jul 21, 2008 08:42 PM
