Waterfall, still, after bleeding coolant system
Old Mar 23, 2017 | 09:34 AM
Bom2oo2's Avatar
Originally Posted by JUKE179r
I've tried everything to bleed the air out the cooling systems. I've done it with a hot engine, cold engine, truck parked on steep incline up hill, raised up the coolant bottle, climate control heat on max and still have the gurgling/waterfall noise when I turn corners.
I even drained the 2 condensate drains under the truck to see if water was in there making the water sloshing noise. They were dry.
I seriously think this could be trapped water inside the firewall area from my cracked windscreen cowl.
If you do bleed proces properly, you will get rid of waterfall noise after a few repeat process with engine cold, if you don't there could be 2 reasons,
1- connecting hoses to heater core are backward (flow trough core should be correct direction) or it won't let air completely escape.
**2- make sure heater core flow's freely, & Is not partially clogged,, Because if it's even a little clogged but water still flows trough it, it will make it very very hard to get rid of air, & some will stay in core,,
When most ppl have a hard time getting rid of waterfall, it's one of these two reasons, mostly the second, (partially clogged heater core) but since they still have some heat coming out of cabin vent's, they don't realize it,,
Old Mar 23, 2017 | 09:37 AM
za105's Avatar
Have you tried opening the T-fitting and raising the expansion tank in the air, ensuring the expansion tank constantly has coolant in it and doesn't get too low to allow air to enter the system?
The best solution for me was to actually fill coolant into the system through the T-fitting. Unscrew the fitting, get an appropriate funnel to fit that tiny hole, and top up coolant through that fitting. That's how I always add coolant now, it eliminates my waterfall for a long time. Waterfall's back somewhat now, but I also haven't topped up in about a year since replacing my leaking water pump gasket.
Old Mar 23, 2017 | 11:50 AM
Jeff Blake's Avatar
The Airlift tool is great. I filled as much as I could by hand (was bone dry), opened bleeder, raised tank, etc. Plugged in the Airlift, and it pushed at least 2 more quarts in.
Old Mar 23, 2017 | 12:12 PM
Tony Luna's Avatar
I posted this a while ago.
Sounds silly, but it works every time - and I've done it many times as I seem to be obsessed with coolant temps and ticking...
  1. Get the front of the truck higher than the rear (ramps, driveway, incline)
  2. Open the bleed port on the upper hose "T" fitting
  3. Fill the overflow tank with coolant
  4. Here comes the silly part - I put my mouth on the overflow tank opening, and blow
  5. The level in the overflow tank goes down as the pressure forces coolant into the system - you can hear air rushing out the bleed port
  6. After two or three times blowing/filling the tank (stop blowing before the tank is completely empty to avoid forcing more air into the system), coolant will start to squirt out the bleed port
  7. I keep blowing coolant out the bleed port as I screw the cap back on (as to not let any air back in through the bleed port)
Works every time - have never heard the "waterfall".
Goes without saying - but - make sure the engine/coolant is not hot.
Bring on the hazing...
Old Mar 23, 2017 | 12:13 PM
Jeff Blake's Avatar
Works every time - and I've done it many times as I seem to be obsessed with coolant temps and ticking...
"With regards to bleeding, this may sound silly - but - with the front of the truck on ramps, I usually
  1. Open the bleed port on the upper hose "T" fitting
  2. Fill the overflow tank with coolant
  3. Here comes the silly part - put my mouth on the overflow tank opening, and blow
  4. The level in the overflow tank goes down as the pressure forces coolant into the system - you can hear air rushing out the bleed port
  5. After two or three times filling the tank (stop blowing before the tank is completely empty to avoid forcing more air into the system), coolant will start to squirt out the bleed port
  6. I keep blowing coolant out the bleed port as I screw the cap back on (as to not let any air back in through the bleed port)
Haha I did the same with the power steering. Works great. The Airlift tool works in the opposite manner, it sucks all the air out, and then displaces it with coolant
Old Mar 24, 2017 | 08:31 AM
abran's Avatar
What a Blowhard!
Old Mar 24, 2017 | 10:40 AM
Tony Luna's Avatar
Originally Posted by abran
What a Blowhard!
Right???
Old Mar 24, 2017 | 11:59 AM
huggi's Avatar
I do the same thing, I did some research.... Our lungs can push about 2 PSI, enough to push fluid.
Old Mar 24, 2017 | 11:04 PM
JUKE179r's Avatar
Thanks for the different methods guys.
My Disco isn't overheating but I'll try the blowing in the overflow tank method this weekend. I'll report back.
Old Mar 25, 2017 | 10:51 AM
Luckyjayb's Avatar
I still get it and I know everything is clear BC everything is new and I bled it countless times. I'm fixing to say the heck with it and go with the inline set up
b c
Aug 6, 2013 12:49 AM
baddiscoII
Mar 28, 2013 10:08 AM
johnnyjohnny
Mar 25, 2013 08:46 PM
MoShadeTree
Apr 2, 2012 10:21 AM
disc oh no
Jan 17, 2011 08:48 AM
