Weather Stripping
Not sure how different the D1 and D2 are on door seals, but I found similar stripping at pep-boys. If you separate the rubber part from the part that matches the interior and clamps on the metal trim, you can glue new stipping on. I fixed a 6" string on the bottom of my drivers door.
on
You might also check with a Rover dismantler like, http://www.roverlandparts.com/
for a used part.
for a used part.
