Weird chirping noise
Old Jun 2, 2014 | 06:01 PM
evansjoem's Avatar
Have a weird chirping noise on drivers side front tire. Wheel hub+bearing are 6 months old. 0-18mph
Old Jun 2, 2014 | 06:14 PM
jeffh's Avatar
well there is the first thing. check you drive shaft. after that check you brakes. ball joints. Does it make a different sound when turning the wheel, i.e. CV joint.
Old Jun 2, 2014 | 08:41 PM
G Reeves's Avatar
Chirping noise is normally associated with front drive shaft. Are you getting any vibration at all? That can be another sympton as well
Old Jun 3, 2014 | 04:59 PM
evansjoem's Avatar
Ball joints are new, no change when turning, almost sounds like dusty brake pads. But from 0-18mph then goes away, what should I look for on the drive shaft
Old Jun 3, 2014 | 06:45 PM
gbob's Avatar
Mine chirped as well. However, I got the "doom-kauff" award because I didn't lube the front prop. That's where the chirping noise came from.
If you have an aftermarket front prop, should have 4 to 5 zerk joints, maybe even a "button" lube joint. Located in the cardon joints. See photo of what I am referring to for the "button" greaseable joint, as well as a couple of zerk joints.
Old Jun 3, 2014 | 08:25 PM
evansjoem's Avatar
I just lubed it the other day
Old Jun 4, 2014 | 12:57 AM
Dane!'s Avatar
Did you buy the chinese hub bearing or the oem one.
Old Jun 4, 2014 | 04:18 AM
gbob's Avatar
what about your serp belt and pulleys?
Old Jun 4, 2014 | 08:41 PM
evansjoem's Avatar
I think it was probably some little sweat shop kids from Bangladesh. Definetly not serpentine belt
Old Jun 5, 2014 | 04:30 AM
gbob's Avatar
pulley?
