Weird Electrical Issues. Any ideas?
2001 Disco 2. Here’s the main issue. The rear right brake light doesn’t work. I ordered a new unit and that doesn’t work either. The left one works fine, and reverse lights on both sides come on. To trouble shoot. I plugged in my left side unit into the right side and for some reason that worked. Then I plugged in my right side unit into my left and that worked as well - so it doesn’t appear to be the bulbs. Not sure if that’s the best way to troubleshoot because of differing pins?
Also, when in park, when I press on the brake pedal I hear a clicking noise coming from the dash and near the shifter.
In addition to this brake light issue, the red emergency break light won’t go away on the dash. The e brake is down but does work when pulled. There’s plenty of brake fluid as well.
Finally, there appears to be some slow electrical draw. If I leave the rover sitting for a couple weeks the battery will be super low or dead. It’s a brand new battery.
The previous owner did some weird electrical upgrades like installing DVD players in the headrests and splicing in an aftermarket radio/head unit (I’ve since taken this out).
Not sure if any of these are connected? Would appreciate some help here - especially on the rear brake light because I can’t get it inspected.
thanks!!
thanks!!
There are fuses in the passenger compartment fusebox for the right lights and left lights. I forget what the number for the right one is, but the icons inside the lid should guide you to the correct one. Pretty sure it's a 10A.
The clicking by the shifter is normal. That's the shift interlock releasing the shift lever.
