Weird - No 3 Amigo lights in IC - factory equipped this way
So thought I would share something strange on the 02 I have - it does not have any ABS fault lights. It does have HDC button, and equipment, and the HDC works correctly. I have ABS code reader - no codes. Not sure if the ABS works correctly, kinda hard to test ABS on fat tire Disco unless there is ice or mud. I noticed it when the bulb check position on the IC did not light up 3 amigos, figured someone had popped the bulbs out so I took the IC out to inspect. Got it out, turns out the IC never was equipped with 3 amigo lights. Anyone ever seen another one like this?
Definitely a diesel cluster. Maybe previous owner replaced the cluster at some point and used the wrong one unknowingly? I doubt it came from the factory that way unless some hungover brit made a mistake.
