Weird noises and vibrations on 2002 with 160,000 miles
So sorting out my $900 discovery I'm finding out the truck is in great shape actually. Hasn't overheated once in over 120 miles of on and off road driving but has some quirks. Normally on acceleration above probably 1500 rpms there's a squeaking sound accompanied by a faint knock. Any idea on what could cause this? Additionally the car will randomly shake around 40-50 miles an hour. Not violently, but annoyingly. I find it odd because sometimes it does and doesn't, and seems like it happens more often when I'm turning the wheel. Shakes the whole car pretty bad but goes away at higher speeds. Wondered if the tires needed balancing or something with suspension. Thanks
There are dozens and dozens of threads on this and other forums about the front driveshaft. It has a single U-joint at one end and a double-cardan joint at the other, which includes two U-joints and a centering balll. That is the end or the trouble most often happens. Inspect the U-joints in your truck and see if each of the three U-joints as a grease fitting. If so, grease all three fully, not stopping until new grease is emerging from each of the four bearing caps of each U-joint. While you're at it grease the U-joint in the rear driveshaft too. Even if it has grease fittings and you grease it well it may be too late. It may be shot already
If the three U-joints in the front driveshaft do not have grease fittings replace it. Immediately. When I addressed the driveshaft in my truck many years ago I bough the U-joints and centering ball and took them to a local driveline shop and had them do the work. All-in it cost me about $150. The cost of good, replacement friveshafts has come way, way down since then. A vendor on this forum called Lucky 8 sells a high-quality replacement front driveshaft for $208. At that price I would simply buy and install a new driveshaft instead of messing around with replacing the U-joints in an old one given the time and hassle involved. Good luck and let us know what you find.
dmatranga
04-11-2016 01:58 PM
ingodaneuf
12-30-2010 08:59 PM
maestro
05-26-2007 02:51 PM
