Weird radio and window issue, ground? Fuse box?
I have a 2003 discovery and whenever I push the window up buttons the radio skips out and the lights dim alittle, what’s causing this what should I test ? This doesn’t happen when the car is running only in ignition
https://share.icloud.com/photos/0tSv...-b45xG679R5cww
This is odd, for sure- does it only happen when you push the up button AND the windows are already all the way up? Just trying to think of things that would draw a lot of current and cause a voltage drop large enough to give your radio headaches. How old is your battery? Any trouble starting the truck?
any ground in particular? I have to put in a new battery holder so I can fix the battery one but should I also clean up the one going to the block
