Weird radio and window issue, ground? Fuse box?
Old Sep 25, 2020 | 06:56 PM
escott16's Avatar
Default Weird radio and window issue, ground? Fuse box?
I have a 2003 discovery and whenever I push the window up buttons the radio skips out and the lights dim alittle, what’s causing this what should I test ? This doesn’t happen when the car is running only in ignition
https://share.icloud.com/photos/0tSv...-b45xG679R5cww
Old Sep 27, 2020 | 06:06 PM
escott16's Avatar
Bump anyone?
Old Sep 27, 2020 | 11:02 PM
greisinb's Avatar
This is odd, for sure- does it only happen when you push the up button AND the windows are already all the way up? Just trying to think of things that would draw a lot of current and cause a voltage drop large enough to give your radio headaches. How old is your battery? Any trouble starting the truck?
Old Sep 28, 2020 | 07:05 AM
escott16's Avatar
yes only when the windows all the way up. Battery is only a year old and is a type65 so it’s decently big. The truck doesn’t have too many issues starting but every now and then it stalls but I think that’s a whole different issue
Old Sep 28, 2020 | 10:24 AM
stxscott's Avatar
May not be related, but you should check your battery -ve ground connections. Sounds as if when you are placing a heavy draw on current (window full up), the battery can't keep up supply. Indicates a weak connection somewhere.
Old Sep 28, 2020 | 10:35 AM
escott16's Avatar
any ground in particular? I have to put in a new battery holder so I can fix the battery one but should I also clean up the one going to the block
Old Sep 29, 2020 | 08:29 AM
stxscott's Avatar
I had a problem with the ground from battery to engine (near alt bracket), but also the ground in the engine bay to the firewall should be checked. There are many posts on ground issues.
4xfungirl
Jan 7, 2018 02:20 PM
machinetech
May 21, 2013 12:32 AM
13xchamps
Oct 13, 2011 05:28 PM
rphotographer
Mar 23, 2011 07:24 PM
MallCop
Dec 17, 2007 08:18 PM
