Electrical Problem
Took out Sony radio and reinstalled original rover radio, must have pinched a wire as 20 amp fuse blew. Replaced fuse and checked all others. Lost dome light with door switch and slide switch also radio light not working. Looked at rave manual looks like controlled by MFU on fuse box. Anybody agree with problem.
It is a plastic box stuck on the back of the fuse panel under the dash. I don't see it having anything to do with radio, but it controls the interior lights. Does radio have a fuse on back? Also hope you hooked up both antenna leads to radio, my PO just plugged in the "FM" and not the AM/FM.
