Weird transfer case leak
I just pulled my front shaft, and when I got the rear flange loose about a tablespoon of transfer case oil came out of where the shaft flange mounts to the transfer case. It doesn't look to be leaking around the transfer case flange, but apparently it's leaking inside it.
Any ideas why it's leaking inside the transfer case flange? If a seal is failing, it seems like it would leak around it, not inside.
I'm a little confused as to what you mean. Did it leak when you pulled the flange off, or when you removed the shaft?
When you pull the flange, you will get some fluid out, it is sealed between the case and the flange, and there is a cotton seal behind the nut for flange to 'seal' against the output shaft.
I've seen fluid creep on the splines between the output shaft and the companion flange. When I rebuild things with companion flanges I put some sealer (ultra black or something similar) to prevent fluid from doing this. Not much gets out this way but the customer doesn't see it this way after paying for a reseal or rebuild.
