well crap!!!! (update)
Old Jan 24, 2009 | 09:44 AM
sloppyjoe's Avatar
Default well crap!!!! (update)
did my plugs and wires last night in the cold and dark garage. swapped in just under 3 hours.
truck runs like crap, stumbles and has no power.
i must have crossed something up. LAME!!!
Old Jan 24, 2009 | 09:47 AM
Default RE: well crap!!!!
DISCO II COIL LAYOUT
TOP
PASS. SIDE DRIVER SIDE
8 5 6 1
2 3 4 7
BOTTOM
Old Jan 24, 2009 | 10:05 AM
sloppyjoe's Avatar
thats what i had drawn on my cheat sheet. i suppose i could have mixed something up though. that or the coil leads are not snapped into place all the way. or i could be mixed at the plugs. im heading off for a round of golf so i will take her apart when i get back and start fresh.
like i said the garage was cold and i was working at night so i did not have the best lighting. so i may have made a mistake in my attempt to do this job in the dark at 30 degrees out.
Old Jan 24, 2009 | 10:13 AM
sloppyjoe's Avatar
looking at the front of the engine the cylinder numbers are this order correct?
coils
8 7
6 5
4 3
2 1
front
llPANCHOll's Avatar
This appears to be the diagram for the coil....
Out of Rave manual..
Dont take this as gospel.. but here it is anyway...
Old Jan 24, 2009 | 10:16 AM
sloppyjoe's Avatar
i was looking at that on my rave as you posted,,,
Old Jan 24, 2009 | 12:09 PM
Disco2Guy's Avatar
I believe the pic from the RAVE is if you are standing at the rear of the truck looking forward. So you need to reverse it if you're looking at it from the front end of the truck. Very stupid.
Old Jan 24, 2009 | 12:24 PM
AK Rover's Avatar
I believe this is proof that the old saying of "no good deed goes unpunished" is true.
Old Jan 24, 2009 | 06:57 PM
sloppyjoe's Avatar
Default RE: well crap!!!! (update)
well i am now a pro at taking apart all the tubes, wires, and ducting on the top of the engine.
in 30 min i was able to have to rig torn apart and back together and running like a champ. turns out 2 of the upper boots were not properly seated. i double checked the routing and everything was good. runs much better,,,
but the service engine light is still on since i did the induction clean with a bottle of seafoam.
any ideas there or will it go off after i put some miles on the rig. it has only been driven a few miles since i did the induction clean
Old Jan 24, 2009 | 07:11 PM
ryanD2's Avatar
it may take several drive cycles for the lamp to go out, ie total warm up and cool down times. Any chance you know what the codes are?
