Went to auto zone and got some error codes??
Old Oct 16, 2007 | 11:06 PM
hollis's Avatar
Default Went to auto zone and got some error codes??
I got three error codes.. p0150
p1174 and p0174
One says oxygen sensor 1 in bank 2
second says cam sensor fault
and the third says that fuel system for bank 2 was too lean..
Ok so any help on these reads would be much appreciated!!
I am most concerned with the one that says cam sensor fault!?
Thanks in advance!
Old Oct 17, 2007 | 01:46 AM
geotrash's Avatar
Default RE: Went to auto zone and got some error codes??
How many miles on the truck? A likely culprit would be O2 sensors for those codes. There are 4 of them.
Old Oct 17, 2007 | 01:55 AM
hollis's Avatar
88000 miles on my 02
Old Oct 17, 2007 | 08:23 AM
YUP!!! you are ready for 4 new 02 sensers. Go to Atlantic British buy them on sale for $59, install them and clear your codes, you should be OK then.
Old Oct 17, 2007 | 12:31 PM
hollis's Avatar
what about the cam sensor fault?? Still 02 sensor?
Old Oct 17, 2007 | 12:35 PM
jwfuller's Avatar
Probably. Hey discomike, what mileage do you recommend changing O2 sensors?
Old Oct 17, 2007 | 12:39 PM
okdiscoguy's Avatar
ORIGINAL: hollis
Not a cam sensor fault.
P1174
Land Rover
Lambda control adaption fault bank 2.Last occurrence - maximum signal
Old Oct 17, 2007 | 01:09 PM
hollis's Avatar
im confused.. what does the Cam Sensor Fault mean? not a 02 sensor?
I also seafoamed it yesterday.. Worked well... would a second round through the brake booster help to clear the rest out or just do harm?
Old Oct 17, 2007 | 01:19 PM
At this point don't worry about the 1174 fault, get your 02 sensers orderd and replaced, then go have the codes read and cleared, you should be fine then and I bet the 1174 will go away.
As for when to replace the 02's, usually before 100,000 depending on the type of driving you do and the fuel used. It is not unusual to see 02 faults showing up in the 80,000 range.
Old Oct 17, 2007 | 01:21 PM
hollis's Avatar
Cool thanks!! sorry to steal my own thread but... any benefit of using seafoam again.. ?
