Wet Carpet
Old Jan 8, 2008 | 07:40 AM
zerochills's Avatar
Default RE: Wet Carpet
checked both my a/c drains, nothing cam out when I squeezed the nipple. also inserted a small wire to see if clogged, only inserted a couple of inches and still nothing came out. I presume they are not clogged? onto the sunroof drains, where should I look?
I also am in the process of airing out the carpet, smelled a bit musty this morning.
Old Jan 8, 2008 | 05:58 PM
okdiscoguy's Avatar
The drains were just a quick rule out. I think you have to drop the headlines to access the sunroof drains. I have an SD, so no sunroofs, sorry.
You can unscrew the side holders in the door jambs and lift up the carpet. Might have to pull the seats too. Throw a couple of bricke in there to hold the carpet up. Should dry out nicely with no smell... I drove through flood waters and leaked into the doors. This process got mine dried out with no smell...
Old Jan 11, 2008 | 06:24 AM
zerochills's Avatar
Alright, like I said prior I had checked the a/c drains and did not seemed to be clogged, Last night we got heavy down poors so I thought it would be a good time to check for sun roof drain leak. Headliner not wet at all, no visible leak from door seal or windshield (dry). However, drivers side floor soaked 'again'. Question: where does the sunroof drain exit the vehicle? could it be possible that it is draining out back into the floor board and not leaking from the headliner? also, floor only wet about 3-4" inwards from door jam. ???
landbeater
Jun 18, 2008 09:05 PM
ajh
Aug 17, 2007 10:33 AM
NWDiscoRover2004
Aug 7, 2007 01:01 PM
drpenaranda
Oct 25, 2005 10:19 PM
