Wet floor passenger seat
Old Aug 11, 2011 | 06:37 PM
DonRW2007's Avatar
Default Wet floor passenger seat
I've been using the AC full tilt for the past two weeks, and finally noticed that my passenger side carpet is soaking wet. Too dark to go poke around right now. Is there a drain line or something over there that I should check for leaks/obstruction? It is water, not coolant.
Any suggestions would be appreciated.
DRW
Old Aug 11, 2011 | 06:42 PM
drowssap's Avatar
there are two one on each side of the engine, pop the hood and check about half way up the firewall.
Old Aug 11, 2011 | 07:42 PM
Al Blue4.6l's Avatar
the drains are on either side of the transmission. - they have little rubber plugs/filters that get clogged up. don't try to unclog them when the trans is hot.
Old Aug 11, 2011 | 10:38 PM
lordmorpheus's Avatar
Do a search for A/C drain tubes on the forum. There are pictures of what you are looking for. As mentioned, to avoid burns, so it when the vehicle is cold, and be prepared to take a shower afterward.
Old Aug 11, 2011 | 11:51 PM
https://landroverforums.com/forum/di...s-42102/page2/
pictures are about 1/2 way down the page.
Old Aug 12, 2011 | 12:54 AM
MNRover14's Avatar
4wd High
Used the info in the thread that lordmorpheus recommended. I first used a coat hanger to relieve the water (in order to avoid the shower after), and then performed a thorough cleaning. Not too tough to find passenger side one.
Old Aug 12, 2011 | 08:09 PM
DonRW2007's Avatar
Wow - thanks guys. I will check this out this weekend and get back with you. Thanks!
DRW
Old Aug 12, 2011 | 08:38 PM
buick215's Avatar
You can also use a garden hose. That is what I used and it worked great and I didn't have to worry about puncturing the drain hose. I did it from the top down so I didn't even have to get under the truck.
Old Aug 13, 2011 | 06:09 PM
DonRW2007's Avatar
Default Done
Got under the truck and poked at / removed / cleaned the little rubber plugs. Got about a cup of water out of the passenger's side and maybe half as much out of the driver's side. Hopefully this did the trick and my carpet will dry out! Thanks again for the help.
DRW
riorover
Nov 15, 2014 05:40 PM
XBlade
Jun 16, 2013 11:26 AM
Spencerfitch
May 3, 2010 02:56 PM
Princess
Sep 15, 2009 08:02 PM
rhino
Jun 20, 2006 11:04 AM
