What is this?
Domino's Pizza sensor. When you pull in the drive thru they know to have the pizza ready and out the window for you to grab. Just a guess, could be wrong.
Art, if you haven't found it yet I think the part is JFT100190
The manual describes it like this:
Sunlight sensor - The sunlight sensor consists of two diodes that provide the ATC ECU with inputs of light intensity, one as sensed coming from the left of the vehicle and one as sensed coming from the right. The inputs are used as a measure of the solar heating effect on vehicle occupants. The sensor is installed in the centre of the fascia upper surface.
