What Is This??
Old Feb 20, 2010 | 11:33 PM
SpyderMan1964's Avatar
Default What Is This??
While doing the head gaskets on our 03 I found this on the floor just after I got the heads off. I should have put something in the picture for size reference but you could just slip a pencil thew it. I have hunted around and can not figure it out where it goes.
One other thing it turns out that my leak was not head gaskets it was the small freeze plug in the back of the drivers side head. Is this something that any of you have run into before? The heads are at the machine shop to get it changed and both pressure tested. I should have them back on Monday.
Old Feb 21, 2010 | 03:24 AM
d2luvr's Avatar
Sure looks like a cyl head locating dowel pin.
Old Feb 21, 2010 | 08:16 AM
lipadj46's Avatar
Maybe a ring from the old rocker cover gaskets.
Old Feb 21, 2010 | 08:20 AM
bikingteacher's Avatar
Your wedding ring? This is quite common. Wives can get jealous when you spend all of your time in the garage working on the Disco, then the rest of the time updating to this forum.
Old Feb 21, 2010 | 01:58 PM
That is one of the funniest things I have heard in a long time...and true.
Old Feb 21, 2010 | 02:07 PM
WARWAGON's Avatar
It's deff. from the rocker cover gaskets. They come with new ones. The leak on the head freeze plug is not common. I've never seen that. But hey anything can happen with these!
Old Feb 21, 2010 | 04:25 PM
Ok thanks guys, I will check the cover gasket when I get home.
In this case I think my wife would like to go back to the garage and work some more, it is her ride. We have had it for a year I have not even driven it, I am in a wheel chair and it does not have hand controles.
Maybe after I get it back on the road I will have to find a set for it! LOL
Old Feb 21, 2010 | 06:33 PM
Broom handles man, broom handles!!
One in your left hand and one in your right, duct tape them to the pedals and BAM!! you are driving the Rover.
